tomtastic
DHCP IP reservation not working in Connectbox Giga
Hello, sorry for writing in English, I unfortunately don't speak Dutch!
I am trying to reserve some IPs in DHCP using the Connectbox Giga but it seems it doesn't work.
When I add any MAC - IP, it shows as 000000 in the list of reserved IPs.
I think the device has a bug?
tomtastic
Thank you, now for some reason it works, without having changed the range or anything else.
Not sure if there was an update or the something else cleared in the connectbox. In any case it seems fine now.
Thanks for the help!
4 Reacties 4
Marinus
@tomtastic
It does work for me, but that does not help you.
What you can do is make the Connectbox Giga powerless (switch it off, pull the plug) for about 30 seconds and then try again.
tomtastic
Thanks for your answer, I have tried that but no difference.
Not sure if it's because I changed my DHCP range? Now it is 192.168.255.x instead of the default.
Marinus
@tomtastic
I did change de DHCP range to 192.168.1.0/24.
Bud I seem to be lucky to not have any issues so far.
for testing purposes you could temporarily revert  the DHCP range back to its original setting of 192.168.178.x and see if it works.
tomtastic
