Ik heb volledige dual stack nodig op mijn verbinding. Ik moet stoppen met het gebruik van de hotspot van mijn telefoon voor Citrix, en dit klinkt als The Way.
Of course it's not really working - just working while someone is paying attention... It stopped working again an hour later. It might have been an active connection from my hotspot that held on after switching networks.
What worked just now was going back to an ethernet connection to the modem instead of wi-fi. I checked the connectbox and there's nothing obvious in network settings that should change how the wifi network is handled vs the wired regarding filtering, etc. Just 2.4/5 toggles and channel optimization.
Whatever it is, I hope it continues to work.
Gebruik je router mode of bridge mode + een eigen router? In geval van router mode, wat geeft de pagina Beheer, Informatie aan in de webinterface van het modem?
In geval van IPv4 Only of Dual-Stack Lite kan dit handmatig worden omgezet naar Full Dual-Stack.
It's in router mode, and it seems to THINK it has IPv6, but I don't see that outside my network consistently with https://ifconfig.co/ or https://test-ipv6.com/
My network IT contact in the office swears that he had the same issue with the modem seeming to have IPv4 and v6 addresses, but not behaving as expected since the middle of last week, and it was fixed with the full stack change.
I'm not in DS lite mode, and I wouldn't say the router is set with IPv4 only but it seems to behave like it is
I noticed that the modem reset and came up Wednesday morning, as the log entries coincide with about the May be coincidence, but I was able to use Citrix Tuesday evening.
The WAN screenshot below is from Friday - when I started responding, but failed to submit it. I was
Wed 18/01/2023
05:21:07 5 MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=e4:57:40:f9:92:26;CMTS-MAC=00:17:10:91:60:95;CM-QOS=1.1;CM-VER=3.1;
Wed 18/01/2023
05:18:15 6 SW download Successful - Via NMS
Wed 18/01/2023
05:16:48 6 SW Download INIT - Via NMS
The eRouter is already using a Full Dual-Stack configuration, the WAN interface has received an IA_NA address and DNSv6 servers from Ziggo's DHCPv6 server. The modem has performed a firmware upgrade on Wednesday.
Could you post your PC's ipconfig output?
I disconnected from my iPhone hotspot that I've been using to let Citrix work so I could get a clean ipconfig, and then one with openvpn up.
I get those two shots and then try my citrix connection. No problems. No grey screen, no black screen, just works.
Which is great, if confusing why it wasn't doing anything in the meantime.
