gabrio81
Port Forwarding - possible on Ziggo modem?
hello, hope it's ok if i write in English, i dont speak any dutch, just moved to AMS recently 😉
I just got the Ziggo router up and running and seems cool, i have the white box and i wanted to ask if it's possible to do Port Forwarding with it, been playing with it all night but the only option seems under IP & port filtering that it's not what i am used to, you cannot specify what port you want to open... is that it?
just for reference this is the router : https://www.ziggo.nl/klantenservice/wifi/modem/connect-box/
thanks a lot,
Gabrio
hanh
Hi Gabrio,
When Port Forwarding (and some more) is not in the Security Menu your ConnectBox runs so-called IPv6 DS-Lite Firmware. See attached image for the Menu you need.
Just call or Chat with Ziggo and ask for replacement by IPv4 Firmware.
https://www.ziggo.nl/klantenservice/contact/
After that, everything will look familiar again.
Regards, Han
2 Reacties 2
hanh
Hi Gabrio,
Regards, Han
gabrio81
Great thanks, I got in touch with support and they have done the change, it seems it will take 24 hours.
thanks,
Gabrio
