andreyleal
Switch from DS-Lite to IPv4
Good afternoon, I'm having constantly speed problems with my Connectbox Giga, the downstream values are negatives and the download speed is below 2mb. I've already checked the coaxial connection, it's directly connected in the wall (no splitter) and the last try I think is to switch the modem's configuration profile from IPv6 DS-Lite to IPv4 only, I read here in the community that it could help. Could please some moderator do the switch?
Thanks in advance.
ipv4 only is no longer possible its now full dual stack ipv4/6
16 Reacties 16
efok
Your signal levels are very low. Could you please post the values of the upstream and a picture of the coax wall outlet?
Madelon
Oud Moderator
Hi @andreyleal, what Robinjoo19 says is correct, add the requested data please, than we will help you get rid of the problems in a different way! 😄
andreyleal
Hi all, thanks for the replies and sorry for my late reply, I was away from home. Here's a pic of the coax wall outlet and a screenshot from the upstream + speed test.
tt14111
The coax outlet picture is missing.
Downstream exhibits DVB-T2 ingress (on 618 MHz) and power is low, too low on some channels. Upstream power is high but acceptable.
efok
@andreylealThe picture of the wall outlet is missing
@tt14111 1 channel says UNSUPPORTED
i haver never seen that
andreyleal
oh, sorry for that, here is it.
tt14111
UNSUPPORTED indicates that the channel could not be locked, in this case due to excessive DVB-T2 ingress causing extremely low MER.
The coax outlet is outdated, as expected. Is this the only outlet inside the property i.e. did you check the meter cupboard?
oh i was expecting to see "not locked"
tt14111
The second downstream table would display NotLocked for the respective channel.
thanks for the info
andreyleal
I've just checked the meter cupboard and found this outlet where there is a single coax cable connected to a 3-way splitter and those 2 cables run through the pipes and probably end up in my living room wall.
tt14111
The modem should be moved to the meter cupboard and connected directly to the AOP. The AOP (VQ601R) is outdated and must be replaced by a technician (free of charge), however connecting the modem to it temporarily should improve stability and speeds significantly. The 3-way splitter is outdated as well and may be omitted.
andreyleal
hmmm, ok, I'll try it and let you know if it works. Thanks for your help.
tt14111
Obtaining your public IPv4 address enables you to verify whether Dual-Stack Lite has been converted to Full Dual-Stack yet. Dual-Stack Lite (CGNAT) uses subnet 213.127.0.0/17, anything else is Full Dual-Stack. If you are using VPN, disable the tunnel before accessing the URL.
