kan iemand mij helpen met ipv6 dhcp instellingen op mikrotik voor /56
Hi All,
My dutch is not very good, so I used google translate to ask the above question. I apologize if the grammar is not correct.
I have a mikrotik router and ziggo modem is in bridge mode. When I request a /56 prefix, I do not get anything. If I request ipv6 address, i only get /64 which I cannot use/route.
Looking for help from anyone who has mikrotik and successfully received a /56 range.
@admin0 Just finished a basic configuration of my mikrotik (routeros 4.49.1) to connect to ziggo ipv6 through a Ubee modem.
At first I was using al sorts of complex scripts from the internet. I got a prefix almost immediately but the rest was difficult.
Now I use the following script to connect all my lan-ports (one network, so I use Bridge) to ether1-WAN (connected to Ubee). Devices in the network get their ipv6 address automatically through SLAAC.
/ipv6 dhcp-client
add add-default-route=yes interface=ether1-WAN pool-name=ziggo-ipv6 \
prefix-hint=::/56 pool-prefix-length=64 request=prefix
/ipv6 nd
set [ find default=yes ] advertise-dns=no advertise-mac-address=no \
hop-limit=64 interface=bridge
/ipv6 address
add address=::1 eui-64=yes advertise=yes from-pool=ziggo-ipv6 \
interface=bridge
That is all. For now I rely on the default firewall settings of the mikrotik.
Good luck!
Chris
I am no expert but what I know is with a bridged modem you get a /56 that you can divide into 256 /64s, 1/64 per internal network/vlan.
/ipv6 dhcp-client
/ipv6 nd
/ipv6 address
interface=bridge
Good luck!
Chris
Nice one @chrisvanlith !
Hi there @admin0! First of all, welcome to the Ziggo Community 🙂 I'm glad you've found us here!
@chrisvanlith was nice enough to share his experiences here with us (thanks Chris!). Did this work for you aswell?
Hi @chrisvanlith .. this worked perfectly. Many thanks.
Thank you for allowing me to post in English
How nice that this worked out @admin0! Thank you for getting back to us and letting us know. Have a lovely day!
