de afgelopen tijd moet ik telkens mijnmodem een reset geven omdat ik mn wifi niet meer zichtbaar is.
Ondertussen werkt het weer tot uiterlijk 6 dagen, wat is het evt advies
In mijn log staat het volgende;
| 18-01-2021 20:39:07 | notice | Illegal - Dropped INPUT packet: SRC=52.19.86.164 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:20:47 | notice | GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.178.234];CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:20:02 | notice | Illegal - Dropped INPUT packet: SRC=209.84.3.123 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:15:30 | notice | REGISTRATION COMPLETE - Waiting for Operational status;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:15:29 | notice | Illegal - Dropped FORWARD packet: SRC=193.27.229.207 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:15:08 | warning | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 01-01-1970 01:01:17 | notice | Cable Modem Reboot - due to power reset;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 20:07:06 | notice | Illegal - Dropped INPUT packet: SRC=45.154.252.109 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 18:41:37 | critical | No Ranging Response received - T3 time-out;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 18:37:25 | notice | Illegal - Dropped INPUT packet: SRC=45.154.252.106 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 13:58:19 | critical | No Ranging Response received - T3 time-out;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
| 18-01-2021 13:56:07 | notice | Illegal - Dropped INPUT packet: SRC=45.154.252.106 MAC=00:01:5C:A0:E0:46;CM-MAC=ac:22:05:35:da:30;CMTS-MAC=00:01:5c:a0:e0:4a;CM-QOS=1.1;CM-VER=3.0; |
kun je het modem een terug zetten naar zijn fabrieksinstellingen
Goedemiddag @Cvdoever en welkom op de Community,
Goed dat je met deze vraag een topic bent gestart. Ik kan mij voorstellen dat het heel vervelend is dat de draadloze verbinding regelmatig wegvalt. Daarom heb ik even een blik geworpen op de connectie tussen
het modem en het netwerk, en deze verbinding ziet er verder prima uit. Kijk anders eens of het probleem op te lossen is met de stappen op deze pagina. Optimaliseer vervolgens je draadloze verbinding
met behulp van deze informatie.
Laat maar weten of het behulp met deze tips en de tip van @anoniemforum gelukt is.
