Modem vraag
@tobiastheebe
3.0 Downstream channels
1 730000000 6.1 40 QAM 256 17
2 602000000 6.8 40 QAM 256 1
3 610000000 6.4 40 QAM 256 2
4 618000000 5.9 40 QAM 256 3
5 626000000 5.9 40 QAM 256 4
6 634000000 5.8 40 QAM 256 5
7 642000000 5.7 40 QAM 256 6
8 650000000 6.1 40 QAM 256 7
9 658000000 6.6 40 QAM 256 8
10 666000000 7 40 QAM 256 9
11 674000000 7.1 40 QAM 256 10
12 682000000 7.4 40 QAM 256 11
13 690000000 7.6 41 QAM 256 12
14 698000000 7.4 40 QAM 256 13
15 706000000 6.7 40 QAM 256 14
16 714000000 6.4 40 QAM 256 15
17 722000000 6.1 40 QAM 256 16
18 738000000 5.8 40 QAM 256 18
19 746000000 5.6 40 QAM 256 19
20 754000000 5.6 40 QAM 256 20
21 762000000 5.6 40 QAM 256 21
22 770000000 5.3 40 QAM 256 22
23 778000000 5 40 QAM 256 23
24 786000000 5 40 QAM 256 24
25 794000000 5 40 QAM 256 25
26 802000000 4.5 40 QAM 256 26
27 810000000 5 40 QAM 256 27
28 818000000 4.8 40 QAM 256 28
29 826000000 4.5 39 QAM 256 29
30 834000000 4.4 39 QAM 256 30
31 842000000 4.1 39 QAM 256 31
32 850000000 3.7 39 QAM 256 32
1 Locked 40 244 3521
2 Locked 40 169 285
3 Locked 40 189 257
4 Locked 40 209 191
5 Locked 40 199 149
6 Locked 40 207 284
7 Locked 40 211 277
8 Locked 40 195 81
9 Locked 40 167 258
10 Locked 40 190 304
11 Locked 40 203 160
12 Locked 40 211 249
13 Locked 41 157 220
14 Locked 40 179 128
15 Locked 40 209 155
16 Locked 40 207 63
17 Locked 40 193 111
18 Locked 40 162 47
19 Locked 40 203 178
20 Locked 40 199 138
21 Locked 40 202 97
22 Locked 40 220 95
23 Locked 40 224 44
24 Locked 40 237 209
25 Locked 40 230 47
26 Locked 40 270 109
27 Locked 40 216 99
28 Locked 40 231 163
29 Locked 39 222 46
30 Locked 39 252 63
31 Locked 39 267 84
32 Locked 39 260 116
3.1 Downstream channels
Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33 119 4K 2333 QAM 4096 858
Channel ID Locked Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33 Locked 38 0.8 3273261672 7
3.0 Upstream channels
0 58800000 43.5 5120 QAM 64 7
1 52000000 43.5 5120 QAM 64 8
2 45200000 43.5 5120 QAM 64 9
3 38400000 44.3 5120 QAM 64 10
0 ATDMA 0 0 1 0
1 ATDMA 0 0 1 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
3.1 Upstream channels
Channel Channel Width (MHz) Power (dBmV) FFT Type Modulation
25 15.2 37.2 2K QAM 64
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts T4 Timeouts
25 OFDMA 304 82000000 4 0
Network Log
Time Priority Description
13-06-2023 22:46:17 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:31:06 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:21:12 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:46 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:06 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:49 notice REGISTRATION COMPLETE - Waiting for Operational status
11-06-2023 19:08:47 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:42 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:40 notice TLV-11 - unrecognized OID;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:19 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:17 notice Honoring MDD; IP provisioning mode = IPv4
11-06-2023 19:08:15 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:06 warning ToD request sent - No Response received;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:07:58 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 20:19:04 warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 04:29:57 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
1.928 Reacties 1.928
hopelijk kan fritz webcare het fixen
al vraag ik me wel af wat dit doet voor de toekomst van dit modem qua upstream frequentie
caesar
Bij mij worden voor DOCSIS 3.1 dezelfde upload frequentie gebruikt, maar volgens de Fritz!box is het kanaal 7.
De start frequentie van de DOCSIS 3.0 kanalen is wel lager geworden. Die was zoiets als 625 MHz, en is nu 578 MHz.
wel jammer dat de fritzbox blijkbaar het kanaal niet koppelt zoals de sagemcom dat deed
en het aantal actieve subcarriers is bij mij iets lager
caesar
@MR_CHIP
Wat bedoel je met koppelen?
de sagemcom koppelde het OFDMA kanaal richting de fm-oproepband, de fritzbox doet dit op een heel andere lagere frequentie
caesar
@MR_CHIP
OK, dus blijkbaar zoekt de Fritz!box de laagst mogelijke frequentie op voor de upload kanalen. Waarom zou dat een probleem zijn?
omdat ziggo niet voor niks het ofdma kanaal heeft verplaatst , aangezien het kanaal op deze frequenties last kan hebben van verstoring
caesar
@MR_CHIP
Normaal gesproken leiden lagere frequenties tot minder storingen. Maar ok, als Ziggo nog steeds deze kanalen aanbiedt, dan zal de Fritz!box ze gaan gebruiken, lijkt mij logisch. Ik heb geen idee hoe dat in zijn werk gaat, maar we kunnen zien dat de Fritz!box het hele spectrum scant. Mogelijk komt hij tot de ontdekking dat het erg rustig is op deze kanalen, en dan gaat hij ze gebruiken. Dat doet hij tenslotte ook met WiFi.
toch blijf ik het vreemd vinden dat ze na de verplaatsing van ofdma naar de 74/89 mhz oid, de oude frequentie ook intact houden , @tobiastheebe  kan ziggo dit uitzoeken waarom het op beide frequenties wordt aangeboden
btw staat hier bij jou ook 917Mhz
caesar
@MR_CHIP
Neen, dat schreef ik al. Bij mij staat dat nu op 578 MHZ, en tot voor kort op zoiets als 625 MHz.
bij mij was daar automatisch 917Mhz als starting frequency ingevuld
OFDMA bevindt zich nu nog in een transitionele fase, na verloop van tijd zullen de lage frequenties komen te vervallen, op dit gedeelte spectrum ligt de ruisvloer hoger waardoor bij sommige klanten nog instabiliteit en/of uitval van het kanaal voorkomt.
578 MHz is het eerste SC-QAM-kanaal. Dit was 602 MHz voordat de SC-QAM-kanalen 24 MHz werden teruggeschoven om ruimte te maken voor een OFDM-kanaal van 168 MHz breed maar vooralsnog geen frequenties hoger dan 1 GHz te gebruiken. 917 MHz is de PLC van het OFDM-kanaal.
hopen dat ooit mijn fritzbox dan net als de sagemcom de juiste ofdma frequenties selecteert
als tzt de lagere frequenties uitgezet wordt heeft de fritzbox weinig keuze , alleen dan nog snap ik niet waarom het verschil tussen wat voor frequentie worden gebruikt tussen de 2 modems zo groot is
ping in de upstream is wel echt een flink stuk lager tho
FRITZwebcare
Beste @MR_CHIP
je hebt sinds kort een FRITZ!Box 6690 Cable. Het is je opgevallen dat je FRITZ!Box op DOCSIS 3.1 in zendrichting op kanaal 25 verbonden is. Je vorige modem was op 80 MHz verbonden.
Als er een probleem is, helpen we je graag verder.
Kan je even uitleggen wat je anders is opgevallen. Valt de verbinding soms weg? Is de verbinding traag? Zijn er andere problemen?
Vriendelijke groeten uit Berlijn,
Je FRITZ! Supportteam
niks vreemds
alleen ik had gedacht dat de fritzbox net zoals de sagemcom op dezelfde manier het ofdma kanaal zou kopppelen dankzij de ofdma verplaatsing
maar misschien kan @tobiastheebe de vraag beter formuleren met technische termen zodat fritzwebcare weet waar ze moeten zoeken waardoor dit zo anders is
De OFDMA CID was en is 25. De frequentie van de eerste subcarrier is nu echter 19 i.p.v. 82 MHz. Dit impliceert dat het CMTS hetzelfde OFDMA-kanaal op twee verschillende gedeeltes frequentiespectrum aanbiedt. Voordat het modem het kanaal op 82 MHz kan koppelen moet de diplex/split 204/258 MHz in gebruik zijn. De FRITZ!Box heeft echter 85/108 MHz geselecteerd, om nog onduidelijk reden.
dankjewel voor je uitleg /hulp in deze
misschien kan @FRITZwebcare dit software matig veranderen op mijn modem , geen idee of dat mogelijk is
