Modem vraag
@tobiastheebe
3.0 Downstream channels
1 730000000 6.1 40 QAM 256 17
2 602000000 6.8 40 QAM 256 1
3 610000000 6.4 40 QAM 256 2
4 618000000 5.9 40 QAM 256 3
5 626000000 5.9 40 QAM 256 4
6 634000000 5.8 40 QAM 256 5
7 642000000 5.7 40 QAM 256 6
8 650000000 6.1 40 QAM 256 7
9 658000000 6.6 40 QAM 256 8
10 666000000 7 40 QAM 256 9
11 674000000 7.1 40 QAM 256 10
12 682000000 7.4 40 QAM 256 11
13 690000000 7.6 41 QAM 256 12
14 698000000 7.4 40 QAM 256 13
15 706000000 6.7 40 QAM 256 14
16 714000000 6.4 40 QAM 256 15
17 722000000 6.1 40 QAM 256 16
18 738000000 5.8 40 QAM 256 18
19 746000000 5.6 40 QAM 256 19
20 754000000 5.6 40 QAM 256 20
21 762000000 5.6 40 QAM 256 21
22 770000000 5.3 40 QAM 256 22
23 778000000 5 40 QAM 256 23
24 786000000 5 40 QAM 256 24
25 794000000 5 40 QAM 256 25
26 802000000 4.5 40 QAM 256 26
27 810000000 5 40 QAM 256 27
28 818000000 4.8 40 QAM 256 28
29 826000000 4.5 39 QAM 256 29
30 834000000 4.4 39 QAM 256 30
31 842000000 4.1 39 QAM 256 31
32 850000000 3.7 39 QAM 256 32
1 Locked 40 244 3521
2 Locked 40 169 285
3 Locked 40 189 257
4 Locked 40 209 191
5 Locked 40 199 149
6 Locked 40 207 284
7 Locked 40 211 277
8 Locked 40 195 81
9 Locked 40 167 258
10 Locked 40 190 304
11 Locked 40 203 160
12 Locked 40 211 249
13 Locked 41 157 220
14 Locked 40 179 128
15 Locked 40 209 155
16 Locked 40 207 63
17 Locked 40 193 111
18 Locked 40 162 47
19 Locked 40 203 178
20 Locked 40 199 138
21 Locked 40 202 97
22 Locked 40 220 95
23 Locked 40 224 44
24 Locked 40 237 209
25 Locked 40 230 47
26 Locked 40 270 109
27 Locked 40 216 99
28 Locked 40 231 163
29 Locked 39 222 46
30 Locked 39 252 63
31 Locked 39 267 84
32 Locked 39 260 116
3.1 Downstream channels
Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33 119 4K 2333 QAM 4096 858
Channel ID Locked Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33 Locked 38 0.8 3273261672 7
3.0 Upstream channels
0 58800000 43.5 5120 QAM 64 7
1 52000000 43.5 5120 QAM 64 8
2 45200000 43.5 5120 QAM 64 9
3 38400000 44.3 5120 QAM 64 10
0 ATDMA 0 0 1 0
1 ATDMA 0 0 1 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
3.1 Upstream channels
Channel Channel Width (MHz) Power (dBmV) FFT Type Modulation
25 15.2 37.2 2K QAM 64
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts T4 Timeouts
25 OFDMA 304 82000000 4 0
Network Log
Time Priority Description
13-06-2023 22:46:17 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:31:06 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:21:12 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:46 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:06 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:49 notice REGISTRATION COMPLETE - Waiting for Operational status
11-06-2023 19:08:47 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:42 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:40 notice TLV-11 - unrecognized OID;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:19 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:17 notice Honoring MDD; IP provisioning mode = IPv4
11-06-2023 19:08:15 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:06 warning ToD request sent - No Response received;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:07:58 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 20:19:04 warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 04:29:57 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
1.905 Reacties 1.905
Thom1990
Level 6
Ik heb ook regelmatig met de Mediabox Next mini dat de IPv6 gateway niet beschikbaar is. En op de computer in Windows 11 is dat veld leeg. Met firmware versie 6.9.22-2302.6 op het Sagemcom modem.
hmm jammer
Thom1990
Level 6
Hoe het nu in de diagnostische gegevens op de mediabox next mini staat
dankjewel voor het mee helpen in ieder geval
@David wanneer komt er een fix , ticket staat al best lang open
David
@MR_CHIP Ik heb hier nog geen oplosdatum voor.
@Thom1990 Weet je toevallig, of zou je willen proberen, of dit ook voorkomt wanneer je in de modem DHCPv6 (Stateful) inschakelt?
Thom1990
Level 6
@David  bedankt voor je bericht. Ik ga die instelling gelijk even testen. 🙂 En laat het jullie over een paar dagen weten. Het is nu ook dat de IPv6 gateway de ene keer wel werkt en dan opeens weg is.
ik zal die instelling niet proberen aangezien android devices dan geen ipv6 hebben die ondersteunen geen DHCPv6 maar alleen SLAAC
geen idee waarom maar vanmiddag kon ik opeens heel slecht gamen
modem info
Netwerk historie
Tijd Prioriteit Omschrijving
25-08-2023 13:12:17noticeCM-STATUS message sent. Event Type Code: 8; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 13:12:06critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 13:12:06criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 13:12:06noticeCM-STATUS message sent. Event Type Code: 7; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 13:12:06criticalNo Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 13:11:48criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:45:15noticeCM-STATUS message sent. Event Type Code: 8; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:45:06criticalNo Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:45:06noticeCM-STATUS message sent. Event Type Code: 7; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:45:05criticalUnicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:45:05critical16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
25-08-2023 12:44:47criticalStarted Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
Thom1990
Level 6
@David bij mij is sinds ik in het modem de instelling naar DHCPv6 Statefull heb veranderd de ipv6 gateway niet meer weggevallen. Ik zelf gebruik alleen IOS devices dus kan het daarom wel even testen.
David
@Thom1990 Prima. Ik heb het teruggekoppeld, bedankt voor je bevindingen. 🙂
@MR_CHIP Afgelopen vrijdagmiddag hadden een aantal modems op je wijkkast ineens een korte maar flinke dip in de OFDMA MER met een piek in de timeouts. Voor nu lijkt dit eenmalig.
ben benieuwd hoe dat kwam , vermoedelijk vanwege verdere glasvezel aanleg in de wijk
@David aangaande ik kan dus alleen SLAAC gebruiken en hierbij valt nog steeds de ipv6 verbinding in apps weg (zoals ookla speedtest )
ik heb kanaal optimlisatie (smart wifi uitstaan ) maar was wel gewend ik dan nog een test vanuit modem naar ziggo toe kon doen voor een speedtest
maar zelfs de eigen site van samknows , realspeed geeft aan dat het modem niet compatible is
David
@MR_CHIP Zonder SmartWifi ingeschakeld kan je geen 'modemspeedtest' uitvoeren.
dat kon ik eerst wel
David
@MR_CHIP Ik moet mezelf corrigeren. De modemsnelheidstest draait apart van SmartWifi. Ik ga het op de testopstelling testen, het zou interessant zijn als dit ook met het ipv6 filter te maken heeft.
@David nu nog minder kan geen eens modem beheren via smart wifi
@David  schreef:
@Thom1990Prima. Ik heb het teruggekoppeld, bedankt voor je bevindingen. 🙂
@MR_CHIPAfgelopen vrijdagmiddag hadden een aantal modems op je wijkkast ineens een korte maar flinke dip in de OFDMA MER met een piek in de timeouts. Voor nu lijkt dit eenmalig.
en nu weer een complete uitval maar dan op het OFDM kanaal , worden/werden er werkzaamheden gedaan gelet op het tijdstip
Vincent
Sinds je laatste post zie ik wel een verandering in het vermogen. Mocht je nog problemen ondervinden, dan vernemen we het graag.
eerst zat het zo
nu zo stuk netter
  dat stuck met duc tape was vrij gehavend door jarenlang te stugge buiging dus daarom die duc tape er omheen
