3.0 Downstream channels
| 1 | 730000000 | 6.1 | 40 | QAM 256 | 17 |
| 2 | 602000000 | 6.8 | 40 | QAM 256 | 1 |
| 3 | 610000000 | 6.4 | 40 | QAM 256 | 2 |
| 4 | 618000000 | 5.9 | 40 | QAM 256 | 3 |
| 5 | 626000000 | 5.9 | 40 | QAM 256 | 4 |
| 6 | 634000000 | 5.8 | 40 | QAM 256 | 5 |
| 7 | 642000000 | 5.7 | 40 | QAM 256 | 6 |
| 8 | 650000000 | 6.1 | 40 | QAM 256 | 7 |
| 9 | 658000000 | 6.6 | 40 | QAM 256 | 8 |
| 10 | 666000000 | 7 | 40 | QAM 256 | 9 |
| 11 | 674000000 | 7.1 | 40 | QAM 256 | 10 |
| 12 | 682000000 | 7.4 | 40 | QAM 256 | 11 |
| 13 | 690000000 | 7.6 | 41 | QAM 256 | 12 |
| 14 | 698000000 | 7.4 | 40 | QAM 256 | 13 |
| 15 | 706000000 | 6.7 | 40 | QAM 256 | 14 |
| 16 | 714000000 | 6.4 | 40 | QAM 256 | 15 |
| 17 | 722000000 | 6.1 | 40 | QAM 256 | 16 |
| 18 | 738000000 | 5.8 | 40 | QAM 256 | 18 |
| 19 | 746000000 | 5.6 | 40 | QAM 256 | 19 |
| 20 | 754000000 | 5.6 | 40 | QAM 256 | 20 |
| 21 | 762000000 | 5.6 | 40 | QAM 256 | 21 |
| 22 | 770000000 | 5.3 | 40 | QAM 256 | 22 |
| 23 | 778000000 | 5 | 40 | QAM 256 | 23 |
| 24 | 786000000 | 5 | 40 | QAM 256 | 24 |
| 25 | 794000000 | 5 | 40 | QAM 256 | 25 |
| 26 | 802000000 | 4.5 | 40 | QAM 256 | 26 |
| 27 | 810000000 | 5 | 40 | QAM 256 | 27 |
| 28 | 818000000 | 4.8 | 40 | QAM 256 | 28 |
| 29 | 826000000 | 4.5 | 39 | QAM 256 | 29 |
| 30 | 834000000 | 4.4 | 39 | QAM 256 | 30 |
| 31 | 842000000 | 4.1 | 39 | QAM 256 | 31 |
| 32 | 850000000 | 3.7 | 39 | QAM 256 | 32 |
| 1 | Locked | 40 | 244 | 3521 |
| 2 | Locked | 40 | 169 | 285 |
| 3 | Locked | 40 | 189 | 257 |
| 4 | Locked | 40 | 209 | 191 |
| 5 | Locked | 40 | 199 | 149 |
| 6 | Locked | 40 | 207 | 284 |
| 7 | Locked | 40 | 211 | 277 |
| 8 | Locked | 40 | 195 | 81 |
| 9 | Locked | 40 | 167 | 258 |
| 10 | Locked | 40 | 190 | 304 |
| 11 | Locked | 40 | 203 | 160 |
| 12 | Locked | 40 | 211 | 249 |
| 13 | Locked | 41 | 157 | 220 |
| 14 | Locked | 40 | 179 | 128 |
| 15 | Locked | 40 | 209 | 155 |
| 16 | Locked | 40 | 207 | 63 |
| 17 | Locked | 40 | 193 | 111 |
| 18 | Locked | 40 | 162 | 47 |
| 19 | Locked | 40 | 203 | 178 |
| 20 | Locked | 40 | 199 | 138 |
| 21 | Locked | 40 | 202 | 97 |
| 22 | Locked | 40 | 220 | 95 |
| 23 | Locked | 40 | 224 | 44 |
| 24 | Locked | 40 | 237 | 209 |
| 25 | Locked | 40 | 230 | 47 |
| 26 | Locked | 40 | 270 | 109 |
| 27 | Locked | 40 | 216 | 99 |
| 28 | Locked | 40 | 231 | 163 |
| 29 | Locked | 39 | 222 | 46 |
| 30 | Locked | 39 | 252 | 63 |
| 31 | Locked | 39 | 267 | 84 |
| 32 | Locked | 39 | 260 | 116 |
3.1 Downstream channels
| 33 | 119 | 4K | 2333 | QAM 4096 | 858 |
| 33 | Locked | 38 | 0.8 | 3273261672 | 7 |
3.0 Upstream channels
| 0 | 58800000 | 43.5 | 5120 | QAM 64 | 7 |
| 1 | 52000000 | 43.5 | 5120 | QAM 64 | 8 |
| 2 | 45200000 | 43.5 | 5120 | QAM 64 | 9 |
| 3 | 38400000 | 44.3 | 5120 | QAM 64 | 10 |
| 0 | ATDMA | 0 | 0 | 1 | 0 |
| 1 | ATDMA | 0 | 0 | 1 | 0 |
| 2 | ATDMA | 0 | 0 | 1 | 0 |
| 3 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
| 25 | 15.2 | 37.2 | 2K | QAM 64 |
| 25 | OFDMA | 304 | 82000000 | 4 | 0 |
Network Log
| 13-06-2023 22:46:17 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 13-06-2023 01:31:06 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 13-06-2023 01:21:12 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 13-06-2023 01:09:46 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 13-06-2023 01:09:06 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:49 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
| 11-06-2023 19:08:47 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:42 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:40 | notice | TLV-11 - unrecognized OID;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:19 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:17 | notice | Honoring MDD; IP provisioning mode = IPv4 |
| 11-06-2023 19:08:15 | critical | No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:08:06 | warning | ToD request sent - No Response received;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 11-06-2023 19:07:58 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 10-06-2023 20:19:04 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
| 10-06-2023 04:29:57 | error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1; |
Maar om nu om elk hikje in het modem hiervan melding te doen.................
@Hatolex als dit zo maar een hikje was had de klachtenafdeling er geen prio/acties op uitgezet wat ze nu wel deden (geen idee wat ze hebben veranderd maar alles is weer in orde ) nog geen T3 fouten
Oke, case closed.
@Hatolex schreef:Oke, case closed.
nee hoor
er staat voor maandag een bel afspraak met mijn contactpersoon van de ziggo klachtenafdeling om te checken ofdat alles echt goed is en dan ga ik ook vragen hoe dit heeft kunnen gebeuren , en het liefst te horen krijgen wat ze precies hebben gedaan
lol mijn buurman met ook een docsis 3.1 modem heeft wel t3 fouten
(ergens bekruipt mij het idee dat ze de t3 fouten op negeren/niet laten zien in modem GUI hebben gezet aluhoedje als dat überhaupt mogelijk is ....)
Die T2 + T3 timeouts lijken vrijwel direct na de laatste reset te zijn voorgekomen. Het is jammer dat de UBC1318 geen T1 t/m T4 timeouts toont in de actuele waarden, dus we weten niet of ze op ATDMA of OFDMA voorgekomen zijn.
@tobiastheebe schreef:Die T2 + T3 timeouts lijken vrijwel direct na de laatste reset te zijn voorgekomen. Het is jammer dat de UBC1318 geen T1 t/m T4 timeouts toont in de actuele waarden, dus we weten niet of ze op ATDMA of OFDMA voorgekomen zijn.
dat is idd wel jammer misschien denk ik er ook wel het ergste van
zolang het bij mij maar goed werkt moet ik maar denken 😛
ergste moment toen was
Ik vraag mij af of de beschikbare data IUC's misschien zijn aangepast op het CMTS, nu er helemaal geen T3 timeouts meer lijken voor te komen op OFDMA. Misschien kun je dat aan jouw buurman vragen?
@tobiastheebe schreef:Ik vraag mij af of de beschikbare data IUC's misschien zijn aangepast op het CMTS, nu er helemaal geen T3 timeouts meer lijken voor te komen op OFDMA. Misschien kun je dat aan jouw buurman vragen?
heeft net gekeken maar is nog steeds hetzelfde als dit min of meer
alle IUC"s zijn er nog in ieder geval
die 3 4 9 10 11 12 13
welke actief is kan je alleen zien vanuit cmts/ev natuurlijk
Inderdaad nog hetzelfde. Er zou wel iets aan de configuratie van de IUC's zelf veranderd kunnen zijn. Ik ben benieuwd naar de feedback vanuit Ziggo.
als die dat wilt geven deel ik dat uiteraard anders kan misschien @Lycke daar naar kijken , eventueel nadat de klacht is afgesloten
Inderdaad, 7.6.15 naar 7.6.16, dus een kleine update.
maar die tekst erachter is toch vreemd , is hier een update topic/melding over en is deze publiekelijk
@tobiastheebeik ben benieuwd wanneer deze massaal uitgerold gaat worden. Hier nog de 7.6.15 aan boord.
nee hoor
Heeft u de antwoorden ontvangen waarop u gehoopt had?
@HBO Fan ben helaas niet gebeld
@HBO Fan ik ben nu net gebeld had niet echt veel meer te zeggen @CobusR @tobiastheebe die man bevestigde wat ik al dacht het lag dus aan de combo casa cmts =+ sagemcom , en dat is inmiddels opgelost door software update /reset/reboot oid van cmts zelf
case closed (waarom ik die minor update heb gehad op modem wist die niet, maar goed merk er zelf weinig van vond het alleen appart zeker omdat ik geen beta tester meer ben, het nog niet publiekelijk is uitgerold )
@tobiastheebe mogen sporadisch uncorrectables op OFDM voor komen
volgens diegene van de klachtenafdeling wordt er gekeken naar het algehele signaal en is dat niet zo erg
profile id bleef wel 3
