Modem vraag
@tobiastheebe
3.0 Downstream channels
1 730000000 6.1 40 QAM 256 17
2 602000000 6.8 40 QAM 256 1
3 610000000 6.4 40 QAM 256 2
4 618000000 5.9 40 QAM 256 3
5 626000000 5.9 40 QAM 256 4
6 634000000 5.8 40 QAM 256 5
7 642000000 5.7 40 QAM 256 6
8 650000000 6.1 40 QAM 256 7
9 658000000 6.6 40 QAM 256 8
10 666000000 7 40 QAM 256 9
11 674000000 7.1 40 QAM 256 10
12 682000000 7.4 40 QAM 256 11
13 690000000 7.6 41 QAM 256 12
14 698000000 7.4 40 QAM 256 13
15 706000000 6.7 40 QAM 256 14
16 714000000 6.4 40 QAM 256 15
17 722000000 6.1 40 QAM 256 16
18 738000000 5.8 40 QAM 256 18
19 746000000 5.6 40 QAM 256 19
20 754000000 5.6 40 QAM 256 20
21 762000000 5.6 40 QAM 256 21
22 770000000 5.3 40 QAM 256 22
23 778000000 5 40 QAM 256 23
24 786000000 5 40 QAM 256 24
25 794000000 5 40 QAM 256 25
26 802000000 4.5 40 QAM 256 26
27 810000000 5 40 QAM 256 27
28 818000000 4.8 40 QAM 256 28
29 826000000 4.5 39 QAM 256 29
30 834000000 4.4 39 QAM 256 30
31 842000000 4.1 39 QAM 256 31
32 850000000 3.7 39 QAM 256 32
1 Locked 40 244 3521
2 Locked 40 169 285
3 Locked 40 189 257
4 Locked 40 209 191
5 Locked 40 199 149
6 Locked 40 207 284
7 Locked 40 211 277
8 Locked 40 195 81
9 Locked 40 167 258
10 Locked 40 190 304
11 Locked 40 203 160
12 Locked 40 211 249
13 Locked 41 157 220
14 Locked 40 179 128
15 Locked 40 209 155
16 Locked 40 207 63
17 Locked 40 193 111
18 Locked 40 162 47
19 Locked 40 203 178
20 Locked 40 199 138
21 Locked 40 202 97
22 Locked 40 220 95
23 Locked 40 224 44
24 Locked 40 237 209
25 Locked 40 230 47
26 Locked 40 270 109
27 Locked 40 216 99
28 Locked 40 231 163
29 Locked 39 222 46
30 Locked 39 252 63
31 Locked 39 267 84
32 Locked 39 260 116
3.1 Downstream channels
Channel Channel Width (MHz) FFT Type Number of Active Subcarriers Modulation (Active Profile) First Active Subcarrier (Hz)
33 119 4K 2333 QAM 4096 858
Channel ID Locked Status RxMER Data (dB) PLC Power (dBmV) Correcteds (Active Profile) Uncorrectables (Active Profile)
33 Locked 38 0.8 3273261672 7
3.0 Upstream channels
0 58800000 43.5 5120 QAM 64 7
1 52000000 43.5 5120 QAM 64 8
2 45200000 43.5 5120 QAM 64 9
3 38400000 44.3 5120 QAM 64 10
0 ATDMA 0 0 1 0
1 ATDMA 0 0 1 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 0 0
3.1 Upstream channels
Channel Channel Width (MHz) Power (dBmV) FFT Type Modulation
25 15.2 37.2 2K QAM 64
Channel Channel Type Number of Active Subcarriers First Active Subcarrier (Hz) T3 Timeouts T4 Timeouts
25 OFDMA 304 82000000 4 0
Network Log
Time Priority Description
13-06-2023 22:46:17 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:31:06 critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:21:12 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:46 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
13-06-2023 01:09:06 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:49 notice REGISTRATION COMPLETE - Waiting for Operational status
11-06-2023 19:08:47 warning REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:42 notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:40 notice TLV-11 - unrecognized OID;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:19 warning DHCP WARNING - Non-critical field invalid in response ;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:17 notice Honoring MDD; IP provisioning mode = IPv4
11-06-2023 19:08:15 critical No Ranging Response received - T3 time-out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:08:06 warning ToD request sent - No Response received;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
11-06-2023 19:07:58 critical Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 20:19:04 warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
10-06-2023 04:29:57 error DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=cc:00:f1:d1:e9:cb;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
1.978 Reacties 1.978
PeterH2020
@Pasi  schreef:
@MR_CHIP  schreef:
...zitten er nog kosten aan het modem ivm niet zelf er erg goed mee om gegaan
Natuurlijk niet ?
Eigenlijk moet dit spul foolproof zijn, want iedere klant wordt ( door Ziggo ) geacht zelf alles te kunnen aansluiten. Waarbij men bij sommige connectoren soms echt hard moet duwen om ze te kunnen plaatsen. Dat men daardoor soms te veel kracht zet, is direct het gevolg.
Dat heet onkunde!
Dit ben ik totaal niet met je eens.
Deze connector zat vanaf het begin al vrij scheef
CobusR
Level 12
Ook ben ik van mening dat de kaber er erg strak omheen gaat en je dus behoorlijk kracht moet zetten ze hadden beter gewoon een f connector gemonteerdaar dan draaien ze die ook weer (te vast) aan met een steeksleutel.
@PeterH2020  schreef:
@Pasi  schreef:
Natuurlijk niet ?
Dat heet onkunde!
Dat kan natuurlijk.
Maar ... hoeveel digibeten denkt u dat er in het Ziggo klantenbestand staan. Ziggo verwacht van al haar klanten, dat als Ziggo een nieuwe modem/router stuurt, de klanten deze zelf aansluiten en plaatsen. Dat daarbij soms e.e.a. niet goed is gewoon in de kosten doorberekend !
ik ben al sinds 2016 ziggo klant en heb mede dankzij @tobiastheebe de nodige coax/docsis kennis opgedaan goed genoeg om de connector zelf niet te verpesten hij zat al iets scheef en ik heb dat stom ook zelf geprobeerd terug te duwen
De connector op het modem is een normale F connector waar kabels met zowel push-on als schroefconnectors op aangesloten kunnen worden. Kabels met push-on connectors zijn geïntroduceerd omdat traditionele schroefconnectors officieel met een momentsleutel aangedraaid moeten worden en je dat niet van particuliere klanten kunt verwachten.
PeterH2020
Laten we hopen dat je problemen in ieder geval tot het verleden behoren............😁
Ik ga het modem vandaag ophalen en later aansluiten PostNL belde weer eens niet aan
@tobiastheebe ik merk sinds het nieuwe modem dat de rxmer op ofdm nu vaker en later 41 blijft en de upstream vermogen is iets lager ( zon 1-2db )
PeterH2020
Om op IUC 9 te kunnen draaien dient de MER 36 of hoger te zijn.
Je haalt nu OFDM en OFDMA door elkaar. Voor OFDM profile ID 3 (4096-QAM) geldt inderdaad een minimale MER van 36 dB, maar 40 dB is aanbevolen.
Kan het echt door nieuw modem komen dan de rxmer 41 blijft
Gelet op de staat van de F connector van het vorige modem is dat inderdaad mogelijk.
PeterH2020
Als dus de MER  te laag is bijvoorbeeld 33 kan de CMTS een andere modulatie gaan toepassen.  Dit voorkomt dan weer CER.
Dat is wat ik bedoel.
Garihd
Een scheve connector is een productie fout. Dan is er maar 1 juiste oplossing foto van  de scheve connector maken en meteen een  nieuw apparaat aanvragen. Maar overal afblijven.
en daar zijn ze weer de uncorrectables lag dus niet aan de scheve connector
@CobusR hier opeens ook weer fouten op OFDMA
the story never ends
eventlog
priority
time
message
error
2024-12-14T22:49:56.000Z
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-12-12T01:59:27.000Z
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-12-12T01:52:05.000Z
CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
error
2024-12-11T10:49:55.000Z
critical
2024-12-09T12:02:48.000Z
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
critical
2024-12-09T12:02:03.000Z
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-12-08T15:55:23.000Z
US profile assignment change. US Chan ID: 25; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-12-08T14:52:13.000Z
US profile assignment change. US Chan ID: 25; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
error
2024-12-07T22:49:52.000Z
critical
2024-12-07T10:51:40.000Z
notice
CM-STATUS message sent. Event Type Code: 6; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
critical
2024-12-07T10:50:54.000Z
error
2024-11-30T22:49:48.000Z
notice
2024-11-30T07:52:35.000Z
notice
2024-11-30T06:49:25.000Z
error
2024-11-27T10:49:46.000Z
notice
2024-11-27T10:20:06.000Z
notice
2024-11-27T10:19:59.000Z
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-11-27T10:19:58.000Z
TLV-11 - unrecognized OID;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
warning
2024-11-27T10:19:46.000Z
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
notice
2024-11-27T10:19:43.000Z
critical
2024-11-27T10:19:22.000Z
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
critical
2024-11-27T10:19:20.000Z
critical
2024-11-27T10:18:17.000Z
critical
2024-11-27T10:15:56.000Z
Cable Modem Reboot from SNMP
critical
2024-11-21T02:12:20.000Z
critical
2024-11-21T01:36:18.000Z
critical
2024-11-21T01:34:26.000Z
No Ranging Response received - T3 time-out;CM-MAC=a0:55:1f:d4:52:09;CMTS-MAC=00:17:10:91:a5:02;CM-QOS=1.1;CM-VER=3.1;
critical
2024-11-21T01:34:25.000Z
critical
2024-11-21T01:22:32.000Z
critical
2024-11-21T01:14:54.000Z
critical
2024-11-21T01:14:24.000Z
Geeft dit aan dat het Ziggo modem niet lekker werkt vaak maar 80mbps upload ipv 100 @tobiastheebe
Ik vind 80 i.p.v. 100 Mbps upload nog geen reden tot zorg en RealSpeed werkt niet altijd optimaal.
Ervaar je zelf iets van instabiliteit/uitval? Ik vind 80 i.p.v. 100 Mbps upload nog geen reden tot zorg en RealSpeed werkt niet altijd optimaal.
Ik vind het vooral vervelend dat ik per dag soms tientallen gb's aan fotos upload en ik dan 80 heb ipv 100 , als ik ruim 100+ per maand betaal
Maar het valt helaas binnen ziggo's met neutraliteit dinges/ garanties
De DS CER en uitval van OFDMA zijn wel zaken waar Ziggo verder naar zou moeten kijken.
