Good evening!
I have a coax cable that is a bit far away from the TV. So I would connect the coax cable to the media box and the media box wirelessly to the TV. Does Ziggo have a solution for that? If not, do they somehow block/prohibit the available HDMI transmitter-receiver sets? Does any of you have experience with these?
Thank you!
Lorenzo
A permanent coax connection is required for linear (live) TV. Ziggo Randapparatuur offers premium quality IEC/IEC coax cables up to 10 meters in length. Using a wireless solution, such as an HDMI transmitter/receiver set, is not recommended nor officially supported.
via wifi gaat dat niet lukken.
hoeveel meter komt de mediabox van de TV af te staan?
Maybe a Next mini is the solution for you: Next Mini - Ziggo TV doet met je mee | Ziggo
Thank you for your response!
It's 1 meter, but there is a (light) wall in between.
Just to clarify, my idea was to use a wireless connection from the mediabox to the TV, not from the coax to the mediabox.
Thank you! I am looking into it now!
But does it get live TV or is it equivalent to using Ziggo Go from e.g. a fireTV stick (which I am using now)?
The Next Mini requires (USB) power and Wi-Fi connections only. This allows you to move it freely along with the TV, provided Wi-Fi signal strength is sufficient. The Next Mini offers the same software features as the Mediabox Next.
