vvitkovskis
How can I resolve CS2010 on the Next Mini?
Dear all,
Good afternoon. I am experiencing issue with gthe Next mini modem, for some reason it is not working and app is throwing an error CS2010. I have tried to connect it via cabel and WiFi, and while running diagnostics it showing no issues with connection. So it must be something with abonnement. I also tried to heractivieren but without success.
Regards,
Vladislavs Vitkovskis
vvitkovskis
hi Ryan!
Good morning. It started to work today, the issue is resolved. I would like to thank everyone for their support!
Much appreciated! 🙂
12 Reacties 12
How did you acquire the box? The box only works if suplied by ziggo.
panda_snorkel
Level 12
That you unplugged the Next Mini and your modem from the electricity circuit? Did this action resolved your problem?
panda_snorkel
Level 12
Also have you tried to set your Next Mini to  factory mode/Fabrieksinstellingen? Did this work for you?
vvitkovskis
Hi!
I have ziggo abbonnement for both TV and Internet since September 2025.
vvitkovskis
Hi!
I did that, did not help.
vvitkovskis
Did not help after factory reset
vvitkovskis
Hi Bert,
Did everything and same error pops up.
@vvitkovskis  schreef:
Hi!
That's not an answer to my question.
vvitkovskis
It was delivered by ziggo together with the wifi router.
Ryan
Hello @vvitkovskis
Sorry to see that the connectiond did not work propper. When we check the signal and the devices, we do see that everything is up and running. Is it resolved in the mean time? Otherwise we will gladly hear from you again.
vvitkovskis
hi Ryan!
Much appreciated! 🙂
